Hi to all that can give me help in testing my Myson MSV 322/07 diverter valve.
over the years I have replaced certain parts on the flowsure 70/90 and had no real bother including the actuator head. This time I think the head could be at fault again or there is no signal to tell it to operate.
Reason, boiler getting up to temperature and the pump overrun thermostat is kicking in but the valve is not turning the 3 port valve to circulate the hot water to cool it's self down. I took off the head and watched it in the normal position ie dhw, when I called for CH it turned 90 degrees as it should, albeit it took some time and was not very strong.
when the pump overrun turns on SHOULD it also turn the 3 port valve by means of the diverter valve. i am sure this is the problem. if I do this manually it circulates the water through the heating system then the boiler cools down then I can get hot water.
So to conclude, should the diverter valve turn the 3 port valve when pump overrun in turn on, if not whats the best way to test it.
Once again thank you.
Bully
Bully
