I have a Potterton EP2002 electronic programmer. The problem is that it heats the water but fails to 'engage' the central heating - either when manually switch on or on the timer.
I wonder if I should simply get a replacement programmer or is the problem more deep rooted and the boiler etc should be investigated (although it was only just serviced a month or so ago).
Ideally I would like to sort this out myself without calling someone out. So any ideas or help gratefully received.
Many thanks!
Rh.
Many thanks!
Rh.
