Potterton EP prgmr very stuborn and refuses to be removed??
2 Oct 2004
hi Folks,
Couple of days ago we noticed the readiators were cold - chilly days, great timing!
Checked out the programmer and it appears to be dead. It's an EP2000 (the older black one). I went down to the local store and the chap advised if power is running to the programmer (yes it is - having checked) then I could replace it with a centaurplus C21 (all he had in), that'll do - £30 thanks very much....
I understand some re-wiring will be involved and I reuse the backplate.
If only it was that easy. How on earth do I get the programmer off the backplate/Wall? I got my torch out and see a hing perhaps across the top but whatever I have tried I cannot get the thing to budge. Very annoying - Whats the secret to removing these darn things?
Thanks... brrrrrrr... quick please my g/friend is moaning about being cold.. ;)
if you can re use the backplate, that must mean your new one has the same backplate, how does your new one separate?
i think i had one of these fkks the other day. bottm right is a small tab approx 1/2 inch in. press with screw driver and tilt upwards, now the one i had was grouted in, just force it up, you think its gonna break, ....
if it does...i got the wrong one.. :rolleyes:
if its black in colour...then ive got the right one.
I have one in my mitts. The tab is IN the groove where the front and back halves join, about 3 cm from the lower right corner. I would suggest it needs a 6mm flat bladed screwdriver.
Fraid yourcentaur has a completely different backplate, but you shouldn't have too much trub moving the wires as long as you mark them before you undo them!
