Hi All,
Let me start by saying i'm no central heating expert, but have a basic knowledge of my system,
I have a halstead best boiler operated by a potterton ep2002 programmer and a grundfos pump, the other day the pump stopped working so i assumed the the pump needed replacing as the boiler was still firing up, so I replaced the pump with a new one only to find the same problem ie. pump would not run.
So then I replaced the front of the programmer with a new one but kept the original backplate as it is the same programmer potterton ep 2002,
once again the boiler fired up and programmer lights were on but again the pump would not run.
I took the front of the programmer off and tested the live feeds to the programmer, the main live feed was fine but pump live seemed dead so i took the front of boiler off and there is a terminal block which reads , live,neutral, earth, switch live, pump live, when i tested pump live again it was dead, just as a matter of elimination i took front of pump off and tested live and it seemed fine??, has anybody any idea why the pump wont run? could it be a faulty programmer backplate?
thanks very much in advance
Rob
Rob
