Potterton EP2002
29 Dec 2007
Yorkshire
Can anyone advise me. I have a Potterton EP2002 and my central heating will not switch off. This is an intermitant problem :cry:
DO the lights "Behave" on the programmer?
If not, probably dud programmer
If so, probably sticking motorised valve.
The lights are working fine but when central heating is supposed to switch off on timer it doesn't. Could this be the Patterson timer that is faulty
More than likely it is the motorised valve that the clock controls. D o you have a 3 port valve or 2 two port valves
As you probably have guessed I am a novice at this how would I find out if it is a 2port or three port valve and is it something I could repair myself
had this same model prog unable to turn of last week
If u slide the programmer to the off position do the lights go off, if not it may be the progammer, there fore needeing a new programmer, for now turn the room stat up down and the water will turn of when your cyliner is up to temperature.
These programmers fail as the NICAD battery causes all sorts of faults.
Replace the battery first as its a 10 quid job.
Turn the power off to your heating system..... does the timer lose its time?
David
