I'm hoping for some help with my home Boiler/CH System.
I have an old Potterton Rs50 and have had a problem these last few weeks with the CH. Boiler seems fine for HW only, but when the CH System is switched on too, it runs for a few (maybe 10) minutes then the pilot and main burner are extinguished with a "ping" noise, requiring a re-light.
System is a follows:
Gravity Fed HW (F&E tank in loft), immersion beneath, pumped CH. So when CH is active HW must also be on.
I get the impression from reading other threads with the same problem on here and other sites that the boiler is overheating when CH is added. Question is why I guess. I suspect air or similar in the system, but don't know how to get it out.
Steps:
Steps:
- Thermocouple replaced fairly recently (Separate Matter, but just FYI).
- New boiler thermostat with probe: Replaced and probe in thermal pocket (in case stat was at fault causing overheat).
- Pump appears to be working because rads get hot, I have to free it up every autumn as it seizes over the summer with no use.
- Loud clunking noise from system when CH is on, think it's a combination of water boiling and gas of some kind in the system, can hear whooshing in the rads.
- Have bled rads, was a little air in one or two but not much. Noise still happens.
- Can work around the problem by turning boiler thermostat down, rads get hot enough, burner and pilot stay alight but this causes the problem that H/W is only warm and not hot.
