I have a Potterton Gold 24 HE with an intermittent fault on the CH side. I'm quite a handy DIY'er but not plumber so please bear with me.
When needed, the wirelss thermostat sends a signal to the boiler to switch on the heating. Nothing wrong their. The pump will begin to run, the boiler fires up and then at some point seems to get "stuck" with the boiler not heating and the pump constantly running. The heating side goes off (the light which indicates the flame goes out) but the pump just runs and runs and will continue to do that until I intervene. I reset the boiler (hold the power switch for a minimum of 5 secs), switch it off and switch in back on again.
After doing the above, the boiler will behave from anything from a few days to a few weeks.
We have no other problems - when the radiators heat they all heat very well with no cold spots on any of them and there is no problem with the hot water.
I flushed the system in December after fixing a leaking towell rail in the bathroom, and added new inhibitor at the time. The system is approx 4 years old. I have bled all the radiators a number of times - no air - and the CH pressure is as per the manufacturers guidelines.
Any advice on this would be appreciated.
Thank you.
Thank you.
