- Joined
- 30 Oct 2022
- Messages
- 8
- Reaction score
- 0
- Country
Hi Everyone,
Having a bit of trouble with my boiler. Our Boiler is located upstairs and the condense pipe drains onto the roof of our extension outside (not ideal I know). When the boiler is in use for extended periods of time, say when the heating is on, a small but steady flow of water is coming out of the condense pipe outside. I've checked the expansion tanks pressure, the PRV is not leaking, just the condense pipe. I'm lead to believe it's the heat exchanger, the only issue is I can't seem to make sense of online forums and articles wether it is the main heat exchanger or the plate heat exchanger. I know I can replace the plate heat exchanger but I understand if it's not this then a new boiler maybe in the cards. Which one could it be?
Thanks in advance for your help!
