I have a Potterton Gold HE24 combi boiler. It has recently started to have a problem where the hot water will go cold after a few seconds of running and getting warm later , the water in the kitchen is fine is hot enough, but in the bathroom it getting cold,warm,cold again , the bathroom just 3meter from the boiler .
the other issue i have the pressure of the boiler dropping down to zero after one hour , and when i fill it with water till 1.2 bars , it dropped again ...
The gas engineer he cleaned and washed the heat exchanger two times but i still have a problem ...
If i put a new heat exchanger will solve my problem ? what about the pressure problem ?
Thanks in advance
Thanks in advance
