- Joined
- 3 Mar 2024
- Messages
- 7
- Reaction score
- 0
- Country
The boiler thermostat for the above has failed. The thermostat is a SOFAL SL 203.01 and the thermostat probe is integral with the simple on/off switch or relay in a housing. In other words, the complete unit needs replacement. Unfortunately, given the age of the boiler, that item is no longer available.
So to replace, I installed an NTC 10KOHM, 2-conductor, measuring range: -50°C to +200°C sensor with the sensor end in the opening in the boiler previously occupied by the sensor end of the SOFAL unit. The new sensor was connected to an STC-3008 temperature controller which enables the boiler to cycle "on" at a (desired) preset lower temperature and to cycle "off" at a (desired) preset upper temperature. In other words, it now functions in the manner of the old SOFAL unit.
However, with the SOFAL unit, there as a control knob to set the (desired) temperature of the boiler in steps of "0", "MIN, "1", "2", "3", "4" and "MAX". Thus, depending on how cold the weather was, you could set the boiler to cycle "off" from presumably different upper limit temperatures. I have no information as to what are the temperatures associate with each of "MIN, "1", "2", "3", "4" and "MAX" nor do I know what the lower temperature is to cause the boiler to switch on.
Thus, after that long winded discourse, does anyone know what are the boiler "off" temperatures are associated with each of "MIN, "1", "2", "3", "4" and "MAX" and what the boiler "on" temperature is?
Thanks.
Thanks.
