potterton lynx 2 boiler problems
29 Nov 2006
Hi I am new to this but am desperate
I have an old potterton lynx 2 combi boiler that firstly is losing pressure daily around 0.3 bar also the hot water lasts around 30 secs before going cold heating when pressure is up works fine
Please help
HI,
i seem to have the same problem with regard to the pressure how did you refill yours as i can not seam to find the filling loop
best regards
nothing clever i'm afraid filling loop visable
U need to find out why its losing pressure - is the prv leaking ?
pressure release valve if this is drained to outside then I think so not loads though
Get the prv sorted then - you are going to get continual probs if you don't
This is probably happening because the expansion vessel is flat as well. Any decent engineer will know how to fix that.
