Howdy all,
OK... I own a potterton Lynx 2 boiler and currently I'm only getting warm water through my taps but the central heating is red hot.
I've been working away out of the country for 3months and while I was away my girlfriend had the boiler serviced. A couple of days later she complained that the boiler was leaking water. I called my personal handy man (aka Dad) and after he had a looked he said a valve was loose which he tighten and solve the leak. The boiler was left open to dry out as the circuit board became wet (not sure as to what extent).
Since this all happened the boiler has produced warm water even if I adjust the temp gauge on the front. Am I right to think I'll need to replace the circuit board (which seems simply enough) or would it be something else.
Much thanks.
P.S The timer makes an awful racket which I put up with for now but if the circuit board needs replacing I may as well change that too.
Much thanks.
