Hi All!
I've been reading the forum for a while now and find it great but this is my first post. I'd like to thank everyone in advance for any help given.
I have a Potterton Lynx 2 Combi boiler which is about 11 years old. Last week it just started showing the reset light all the time. I decided it must be the PCB so I fitted a new one. Everything seemed to work but then I noticed that the CH would not respond to the temp dial on the front of the boiler. When the CH is switched on the boiler burns at full flame until the CH overheat thermostat kicks in and cuts off the flame. This really confused me as the hot water temp dial works correctly and the flame changes between high and low and off to keep the hot water at the temp set. I suspected the CH temp sensor may be faulty so I got a new one but there is no difference. I then thought the new PCB may be faulty so I exchanged it for a replacement but again the problem is still there.
Apart from the CH overheating, everything works properly - the pump runs and the radiators get hot etc. One strange thing I noticed was that when the CH gets to a temp that I believe is above the temp set by the dial on the front, if you turn the dial to the middle and then down to minimum quickly, the flame momentarily becomes lower, then returns to full flame accompanied by a single click sound which sounds like one of the relays on the PCB. I thought at one point it may be the gas valve but then didn't understand why this would work for the hot water. I'm running out of ideas now - does anyone have any suggestions?
