Potterton lynx2 Heating not cutting out
12 Dec 2005
Hi Please help!!!!!!!! I have a potterton lynx 2 combi boiler, it works fine for hot water, but i have recently added a addtional radiator since then the central heating is constanly running it nevers cuts out as it used to, before it used to run for about 30-40mins and cut for 10-15mins now it runs for 3 hours then i have to turn it off. the control on the front is set to under half way, there is a total of 6 rads and 4 are doubles the biggest is 520x2000mm Any ideas
If the boiler ran the heating for 30-40 minutes before getting to the set temperature and you have added an extra radiator then probably the set CH output is marginally low.
I would wonder why you are bothered if its adequately heating your house. I suppose increasing the CH output would be the answer but I am not convinced that you need to make any changes.
Tony
PS He has posted exactly the same question on another site and was not very polite to me there!
