The boiler has suddenly stopped heating the radiators but is still heating the hot water.
I found a DIY site and carried out the following:- Checking the header tank first in the loft I found that a family of mice that I had recently heard and poisoned had drowned. I emptied the tank, cleaned it and refilled with water. Thinking that a dead mouse may have entered the outlet pipe and blocked it I then emptied all radiators, refilled and bled them. So I knew that all rads and the headed tank were full.
I disconnected the power and gas to the boiler, removed the front cover and cleaned it inside thourougly but could see nothing obviously wrong. I then repaced the cover and turned the boiler thermostat to off. switched the power on, reset the timer and set it to Auto / 24hrs. I then turned the boiler thermostat on and it fired up. After a short time I switched the hot water off in hope that the central heating would remain on but the boiler shut down. I swithced the hot water back to auto and the boiler fired up again.
I have another single thermostat that I am about to disconnect for a trial but I do not feel that this will change anything. My installation manual says that all the parts that have a shelf life are easy to replace but I do not know what.
Would like to hear from anyone who can help as I hate being ripped of by so called experts.
Full of Hope
Full of Hope
