Help! Recently i had a problem with the Potterton motorised valve (type MPE322 - 3port) fitted in my central heating system. The hot water would work OK but the valve would not motor open to switch on the central heating...........SO.......I replaced the actuator with the identical model, carefully wired it up as the old 1 - and switched it all back on.
Bingo! Everything is working fine - the valve is happily motoring to each position - execept for 1 small problem - when I have Heating only on and it switches off (either via the thermostat or controller) - the valve should Spring back to close the heating port with heating off (port B hot water port open only) right???
But mine doesn't - it stays in the Heating port open only position - and if i listen i can hear the actuator humming as its power to open right? Maybe my old valve had this problem and thats why it burnt out - i'm guessing the valves ain't designed to be powered on all the time.......
So can anyone help me and point me in the right direction - I figure this is an electrical wiring problem - but where and how to start checking thro the system?? The junction box is a mass of terminals and wires and not marked - i feel fairly comfortable sorting out electrics if someone could point me in the right direction - things it might be - sequence to check the circuits in, etc,etc..........
If you need more info please let me know.
I'll be very grateful if i can get help to sort this - and so would the g/f who's fed up with talk of valves and heating
Thanks!!!!!
Thanks!!!!!
