POTTERTON NETAHEAT 10-16 - NO HEAT
2 Oct 2004
Hi
I was wondering if anyone can help. I have a potterton Netaheat 10-16 boiler. The water is still getting hot and it fires up but it does not make the radiators heat.
Can anybody shed any light on this as I can't get anybody out to look at it till the middle of next week.
Bec
should I be able to tell if the pump is running by putting my hand on it
Normally yes, if it;'s got a big shiny screw in the middle you can unscrew it and check if the shaft is going round, put a rag under it as it will dribble water, if it's not you can put a thinner screwdriver down the middle and try turning the shaft to see if it's stuck, if the pump has power to it and isnt working it's either stuck or nackered.
