- Joined
- 6 May 2004
- Messages
- 2
- Reaction score
- 0
- Country
I am trying to replace the pressure switch in the above boiler. The original part has been superceded by a new design which has the tube connectors in an entirely different place to the old one. My problem is that I am not sure which tube connects to the positive terminal and which to the neg (on the new part)? The old part is not marked in any way and neither are the boiler tubes they come from.
Anyone got any clues? Thanks in advance!
>>>>update 7/5/04
I worked it out already for myself as I couldn't wait any longer for HEAT!!, but in case anyone else has the same problem, here's the answer:
the tube that was attached to the FRONT of the old switch (ie the side without the electrical connections) goes to the POSITIVE inlet on the new switch. Further, the wiring is slightly different. The orange and white wires should be swapped over on the new part. You can either do this when you transfer the wires to the new part from the old or by swapping them at the PCB end instead if you've already installed it and can't be bothered to take it apart fully again!
>>>>update 7/5/04
