Hi
Drained, flushed and replaced a radiator in my vented Potterton Netaheat 10-16 CH system. The header tank filled ok but the pump doesn't appear to pump water around the system when the Boiler is turned on.
I turn on the boiler by turning up the main Thermostat, I can hear water initially move (gurgle!) inside the boiler and there is the sound of running water inside the boiler, but the Header Tank isn't draining to refill the radiators. It also sounds like a pump is working (once a second pushing water into the boiler?). The boiler front gets warm, but the main gas boiler hasn't ignited, so not sure why this is?
Bleed valves on the rads are open but no air is being expelled.
Any help or advice on refilling a Potterton Netaheat CH System welcome!
If you need any further info, please let me know.
Neil
Neil
