- Joined
- 19 Apr 2005
- Messages
- 57
- Reaction score
- 1
- Country
After some advice.
After a weeks holiday with the central heating off, there was some brown water under the boiler and it did not fire up.
Called out BG under the 3* they replaced an electrode, advised the heat exchanger was leaking. probably because it was cold where off for a week.
They advise need a new boiler.
I have had 3 quotes so far varying information ref new rules and regs.
I am told you cannot get the replacement Heat Exchange as its so old. Also told to remove the boiler from the backplate is no-no, even if I could find parts. Had quotes for replacement boiler from £1600 (standard boiler) to £3200 for a condensing boiler + lots of what i think is unneccessary work. BG came out around £2400
I can get a worcester bosche boiler from local plumbers for around £800 including flue (correct BTU rated, house has been measured) and most likely get it fitted by a relative who is a proficient plumber but not corgi registered.
Questions:
Should we write off the old boiler, ie. is the advise we have correct?
Should we replace with a standard boiler for £1600 all in?
Should I get a worcester bosche and 'self fit'?
Any advice appreciated.
(editing subject from 10-40 to 10-16)
Questions:
