- Joined
- 2 Apr 2004
- Messages
- 2
- Reaction score
- 0
- Country
I have a wall mounted gas powered Potterton Netaheat 10-16.
Next to it is a Randall 102 Timer. It has options for "Hot Water Only" and "Central Heating and Hot Water". The switch is turned to "Central Heating and Hot Water".
I think the boiler then sends its water to the tank in the cupboard. There is one of those little white boxes stuck to a pipe near the tank.
The central heating works fine.
For the last week we have had intermittent hot water. For instance occasionally the hot tap will produce hot water but then it will turn into a trickle and slowly dry up... as if there is no more water left.
I've tried reading through as many of the questions and answers on this forum but cannot work out what is wrong.
Is the tank not filling up?
Is it something to do with that little white box that's stuck to the side of a pipe in the cupboard and switches between hot water and central heating?
Is it to do with too much air being in the wrong place?
I just don't know and I hope someone can help to throw some light on the problem.
