I have a potterton netaheat, been fantastic until now. Flummoxed most heating engineers. It started blowing the fuse on the psb. So a new psb, air prssure switch put in, still not working, so new fan put in, still not working. Any ideas please?
Wires tested using multimeter test ok. Both fuses were blowing when the timer switched system on. Now not blowing, pump sounds like its pumping but fan not working.
