Hi Guys,
My Boiler is a Potterton Netheat Profile 50e. It was in the house when I bought it so could be ancient but has worked flawlessly for the past 2 years.
This only begun last night, prior to this the boiler has always worked fine and has not shown these symptoms before. I have also not changed anything as far as I am aware.
When cold, ie first thing in the morning, the boiler fires as normal and starts to heat the water or central heating. This boiler seems to extinguish for a minute or two every so often even though it still hasn't heated the water to temperature, but I think this is normal as I seem to remember it always doing this. When it tries to reignite after one of these pauses, the fan comes on as normal, I hear a ticking noise and the pilot light ignite as normal, but normally I then see the boiler fire up through the small window in the front. However, it does not do this. The pilot light remains on and the fan continues to blow. If I go outside and check the flue there is warmish air coming out but as the boiler cools again, the air obviously gets cooler.
It does not seem to stop for the pauses now either, but I am guessing it is not doing this because it does not feel it is getting how enough to warrant that pause.
Now if I turn the timer off and wait for a few hours, I am guessing until everything is cold again. I can get the boiler to work perfectly again, it ignites fine but only until it tries to make that first pause again.
HELP!!! Is it going to be expensive???
I am guessing I will need to call an engineer, can anyone recommend one that will not fleece me in the Watford area? I have seen those consumer programs on TV and they have scared the bejesus out of me when it comes to boilers.
Any advice would be really appreciated.
Thx,
MaKS
Thx,
MaKS
