I have a Potterton Netaheat boiler which keeps switching off after a while.
I recently drained the CH as one radiator value was leaking. Took me 2 days to get all the radiators working but it's difficult to get the entire CH hot as the boiler keeps switching off. Hot water is fine. Problem is worse in the mornings, radiators are luke warm, but in evening after leaving system on for 5 hours all is well. The water pump is running fine, the pipes out of this are HOT, the honeywell valve doesn't seem to spring back after being left in 'open' position. One vent on the side of the hot water cylinder needs frequent venting though (about 5 seconds worth of air is expelled).
The boiler was serviced last year. Could it be a fan problem (which seems to be running fine when boiler is on).
