Potterton not igniting
27 Jul 2006
Kent
I have a Potterton Suprima 50L, and it's not igniting. Looking through the instructions it seems to go into 'lockout' with the red LED flashing - which as I understand it means the system can't ignite so it gives up.
Of course I'll need to get an engineer out, but having never had to get one out in my life I'd be greatful if anyone could give me an idea as to what the fault may be - I'm very paranoid of getting ripped off with something I don't know much about!
Can anyone recommned a method to locate a trusted CORGI engineer?
Thanks in advance,
Graham
it could be locking out for any number of reasons, they are prone to this. what happens when you reset the boiler, does it go to lockout again? you can find a good corgi regd engineer by visiting www.corgi-gas-safety.com. type in your postcode and you should get a choice of at least five local guys (or gals). in your area.
Thanks for the quick reply superskanker.
Yes, when I reset the same happens.
Graham
It is quite likely to be a faulty PCB and the redesigned replacement is quite expensive, almost £200 just for the part.
It might be better to consider a replacement condensing boiler if your gas bill is very high.
Tony
Tony
Tony you on commission today for flogging steamers.
This is the second person today you`ve told to consider getting a condensing boiler.
Personally i think you`re better of going on E-bay get your self a new P.C.B for 75 fat ones, Get it fitted and then forget about it. Apart from the old P.C.B these are quite a reliable boiler.
Back to condensing boilers if you want to save the planet with your emissions like the good old U.S of A then get a condenser . If you want a higher gas bill then also get a condenser.
This is now becoming a common problem where the customer belives there gas bill will plummet with a new condensing boiler.
In very few cases have i seen this to be the case
I have seen some failed new design suprima PCBS !!!
How can a condensing boiler consume more gas than a non condensing boiler? ( Unless its a Potterton perhaps? )
I wonder if the PCB reconditioners could do a Vitodens 300 WB3 main pcb? Actually badged Landis and Gyr or however its spelt after a bottle of Dumisani !
Tony
No, really ?
Given sufficient information, I don't see why not
Looking through my old posts I came across this. It actually turns out that the pressure was very low as I'd changed a radiator. I wasn't aware that there was a pressure valve next to the tank!
Graham
