Hi, I have a Potterton Performa 24 that seems to be running fine apart from when the CH is on after a while the boiler makes a banging sound about every 30 secs for a bit then its fine. It doesn't seem to do it when the burner is on, only when the pump runs. DHW does not cause the same problem.
Any thoughts on what could be causing this?
From googling I think it could be to do with flow or kettling but I'm not quite sure.
Incidentally it had a inspection / service a week ago and nothing came up.
btw its around 8 years old.
Many thanks in advance
