I have replaced the hot water diaphragm, using the instructions below:
"Isolate boiler electrics, remove dhw flow switch, isolate cold inlet under boiler,open a hot tap to remove any residual water pressure...."
worked a treat, now I need to change the central heating diaphragm, my question is, do I need to do anything else/ different to avoid mass water spillage when I remove the Central Heating Pressure Differential Valve to get to the diaphragm, like release the pressure in the CH system? or are the instructions above the same?
Thanks in advance
Thanks in advance
