I have a Potterton performa 24 bolier and there is a problem with the DHW. When the DHW is switched on the pin stays retracted in the pressure differential valve, hence the micro switch is not activated on so no DHW. There is a small water leak from the differential valve coming from where the pin itself is (rather than around the edges of the differential). I am a complete novice and not sure what to do, I have only found out the above by reading up on the internet.
Would I be right in assuming the problem is contained within the differential or could it be elesewhere in the boiler. I have opened up the differentail and can find no obvious damage but then again as I have not done this before not sure what a normal one should look like. If it is the differential should I replace the whole brass unit or can I replace the parts inside i.e the black rubber like seal and white plastic parts with pins on the end? What is the cost likely to be?
Any help greatly appreciated.
