Hey guys,
Here's a question for all you heating engineers (I'm a drains and plumbing peasant!). My friends boiler Potterton Performa 24 is leaking from the front face of what I believe to be the diverter valve/3 way valve. There is a small nut with some sort of spindle in the centre, and the water is weeping slowly from this. (Mounted in front of this nut appears to be an electromagnetic switch if that helps?) Is this for bleeding air/ operating the diverter valve? Can this nut be replaced, is this a common problem.? Any feedback greatfully received
This is the potterton pdf: http://www.potterton.co.uk/products/newliterature/Potterton Performa.pdf
