Hi I have a potterton performa 24 boiler, about 5 years old. Been serviced 3 months ago after suffering from low pressure. The plumber suspected the over pressure value and duly replaced it, at the same time he mentioned we has 2 small leaks. 1 from the switch on the diverter manifold and 1 from the switch of the pressure differential swith. Result is constant leak, no pressure but the boiler fires up and gives hot water. I am worried that in winter when I need to use the radiators the leak will get worse, I will lose pressure and the boiler wont fire up.
Can i buy replacement washers/o-rings to stop the leaks or do I need a whole new diverter assembly?
if I need a new assembly how easy is it to replace? I am competent at DIY and feel comfortable tackling this job, just need a little direction.
Many thanks
Tony
Many thanks
Tony
