Having had a Potterton Lynx combi that gave virtually trouble-free service for 12 years I replaced it about 4 years ago with a Potterton Performa 28. The Performa has been nothing but aggravation and excessive cost for the last couple of years having had a boiler engineer in to replace the push-rod seals and diaphragms on the diverter valve twice, a leaking DHW sensor, and a u/s air pressure switch.
Recently, no matter what I set the CH control to it only delivered lukewarm water to the rads. Rather than spend more money on getting in a boiler man again I thought the most likely cause was a partially blocked filter on the CH return isolating valve and removed and cleaned it. It was partially blocked with sludge but not enough to reduce the flow drastically. Anyway I put it back and reset the boiler and it worked fine. However, as I closed the dropdown front fascia panel the boiler shutdown and when I reset it again the fan and the pump start the boiler ignites but it shuts down within about 2 seconds. It doesn’t lockout but simply repeats this cyclic starting-stopping continuously until I switch it off.
It was frosty last night and this morning and I need it sorted fast. Any ideas what’s wrong and how to fix ?
