I have a potterton performa 30HE and the small led on the front panel has started coming on to show fault on pump or low system pressure I have found that when I manually press the pin on the top of the diverter manifold (central heating differential valve) it all works fine again and this also has a little water around it so I assume this is the problem,
I have the service instruction book but is this a simple job (your advice please).
Can you also tell me the best place for parts? And the procedure to drain the primary circuit.
Many thanks
Many thanks
