Hi I have just part drained the system to disconnect a radiator and fit it in a different position in the same room, the water that drained from the radiator was rather mucky. After refilling and venting everywhere I find that although the CH works OK, the DHW does not.
With the boiler set to CH/DHW the heating is OK but Cold at the DHW outlet. With boiler set to DHW only the boiler does not ignte when outlet tap turned on.
Would appreciate any help.
Ian
Ian
