Hi all. I need a bit of advise. About 9 months ago my combi boiler started leaking. I took the cover off and noticed it was coming from the pin that that operates the microswitch on the differential pressure valve/ flow sensor. So I popped down to my local central heating place and replaced the whole valve. Now it's leaking again from the pin! do I need to get the whole new assembly again or will a replacment diaphragm fix this problem?
