Greetings Folks
I hope some one out there can help me to diagnose the problem with my Potterton Profile 80, which will not light.
The system provides both CH and hot water, the control pannel/timer appears work OK as the pump in the boiler can be hear to run when it is on.
The boiler thermostat knob on the front which goes from 0 - 9 also appears to work, as the system will click off or on when the knob is moved to/from the 0 position. This will aslo cause the pump to cick-in if the timer is set to 'on'. the only thing it does not do is fire up.
It does not appear to be a problem with the re-set button under the pcb - as this has not 'popped' out and even when manually re-set it did not cure the problem.
Any help appreciated.
Cheers
Nemo
Cheers
Nemo
