Potterton prima 30F
11 Nov 2010
Cambridgeshire
have a Potterton prima 30F that will not continue the lighting sequence after the fan has started. The fan runs perfect, the air tubes are clear, the air pressure switch is new , the PCB is new the ht spark wire is good so is the electrode, the inner flue tube and outer air duct are good but the boiler will not light, the fan just runs on and on. Can anyone help
Peter
Is the aps closing? Is there a spark visible.Unless you are competent a good boiler engineer should sort that in minutes.
