Potterton Probs
1 Oct 2005
Hampshire
Hi, can anyone help I awoke this morning to find my electric is tripped.
The cause seems to be my boiler its a potterton suprima 50L.
It trips the rcd as soon as i switch it on.
Can anyone point me in the right direction or if there are any common faults
I should be aware of.
Thanks Bry
Probably the pump. If you can safely isolate it you'll be able to prove.
I had a similar problem back in 2005 and I posted on here and was told that the pcb was a common fault.
Back then I removed the boiler fan and plugged it into a plug socket
with a lead and span it up. It ran fine so I re-fitted it and all my problems went away.
