Hi, can anyone please help. I have just had installed a new Potterton 40Le boiler. I have gravity fed hot water and pumped CH. I had a Randall 102 programmer connected at the time.
After installing the boiler the engineer reconnected the programmer but could not get Hot water only. When switched to Water and CH everything works fine, when switched to Water Only, the pump keeps running but the boiler does not fire up. The Profile boiler has a pump over run facility?
There is now obviously something wrong with the wiring from the 102 to the boiler.
I intend to replace the old 102 with a Danfoss FP715 programmer, could anyone supply me with a wiring diagram to connect the FP715 programmer, Pump and the standard honeywell room stat to the Potterton Profile 40LE boiler.
Hope the detail below explains the connections.
Boiler block is as follows:
Pump L N E
Mains SWL N L E
The Randall 102 has points 1,2,3,4,5,6
The MainsInput(L) is connected to (3) on the programmer.
The MainsInput(N) is connected to (5) on the programmer.
Points 3 and 6 are linked on the programmer.
Point 1 on the programmer is connected Mains(L) on ther boiler block.
Point 4 on the programmer is connected Mains(E) on ther boiler block.
ROOM STAT:
The room stat (L) is connected to (2) on the programmer.
The room stat (E) ) is connected to (4) on the programmer.
The room stat (N) ) is connected to (SWL) on the Boiler block.
PUMP:
The Pump(L) is connected to (Pump L) on the Boiler block.
The Pump(N) is connected to (Pump N) on the Boiler block.
The Pump(E) is connected to (Pump E) on the Boiler block.
The FP715 block is as follows;
N L 1 2 3 4
Thanks in advance for any help you can give me.
John.....
Pump L N E
Mains SWL N L E
ROOM STAT:
PUMP:
N L 1 2 3 4
John.....
