S
sai_2
before I call in the cavalry, I'd appreciate any pointers on my problem.
I have:
Profile 50e
Fully pumped system
7 rads, all but the first one have theromostatic controls
All rads are on
Central thermostat is working ok
Pump is working ok
So the boiler does this when it is advanced or the timer hits go-time:
Cycles round a few times making the usual breathing type noises
Then clicks and sparks into life
But only the pilot light is lighting up or something because its not the full on set of flames that you normally see.
I've checked the brown reset button underneath and powered the unit off/on, but its the same. Just sparks up and no strong flames.
Occasionally in the last few weeks it has worked properly, but not the majority of the time. I couldn't get it working at all this morning (immersion saved the day )
Any suggestions? This has started in the last few weeks. It does it whether the thermostat is high/lo, control on boiler is hi/lo, hw only or hw/ch..
Thanks.
I have:
Profile 50e
Fully pumped system
All rads are on
Pump is working ok
Thanks.
