S
Simonbeasley1
I have a Potterton Profile fully pumped y plan system. The problem i am having is that unless the boiler stat is set to 2-3 setting the boiler trips out. Air is heard in the boiler or could be kettling. I have checked the pump which is on setting 2 if it is on 3 then i get pumping of water through the vent pipe. Because the boiler is on setting 2-3 it fails to get the rads heating the room up and the room stat is never satisfied.
at the weekend i intend to install a new pump and try backwards filling via the boilers drain off that is on the flow close to boiler. I have already installed AAV's just past the mid position valve on both entrance to hot water cylinder and flow to heating to try and remove any air.
If it is air how do i go about getting the air out of the boilers heat exchanger/flow and return. Do i do a system boil up by removing the thermostats (don't like the idea as part of system has a few plastic hep2o elbows 2meters past the boiler on flow pipework).
If it is kettling do i take the heat exchanger out and give it a good clean up. or is their a product by say fernox or sentinel that i can use.
This problem is really annoying and now the cold weather is set in its getting colder and the poor not well boiler is suffering. Any help would be greatly appreciated as i'm contenplating just installing a new boiler.
Just wanted to say that flow and returns are correctly positioned likewise are the vent and feed pipes before the pump.
cheers
Simon
cheers
Simon
