Potterton Profile 60e - CH comes on when I switch on HW.
16 Jul 2011
Cheshire
Hi, we've got a Potterton Profile 60e, whenever the hot water comes on the central heating kicks in too.
We recently replaced the thermostat/controller with a new one. We still have the same problem, the controller shows that the HW is on, but not the CH, despite this the radiators are definitely coming on.
Any ideas?
Please keep answers in laymens terms :)
Many Thanks
It's been a problem before and after fitting the new thermostat/control unit - when I say thermostat I mean the unit we use to set the on and off times for the heating, not something internal to the boiler.
So it's probably an issue with the way the boiler itself is wired?
Cheers
Uncle T
what makes you think the boiler is at fault.
the boiler just receives a signal to fire up it don't know where the water is going.
i'd be checking a faulty 3 port first.
Ah OK, the boiler just heats the water, there's a 3-way valve that decides where the water goes? Makes sense. Thanks for your help...
How would I check it's working?
Like I said, I'm a layman, no plumbing or electrical experience.
The 3 port has 3 pipes to it.
1 from pump
1 to cylinder
1 to heating/rads
switch system on from cold HW only the pipe from pump will be hot then pipe to cylinder will become hot.
feel the pipe on the rad side of the 3 port does it get hot ?
feel it about 6" to 12" away from valve if it gets hot same as others then the valve is passing not shutting the heating circuit fully.
useally a faulty rubber ball or crud in the port stopping it fully closing.
Exactly, 9 times out of 10 the valve is passing, however did have a faulty clock the other day so if there are no lights there it will be the valve passing
Thank you folks, very much appreciated :)
I've located the 3-way and I'm trying different settings to see how it responds. Many thanks!
