I have just recently moved into my new home, which has a Potterton Profile 80 boiler heating a vented CH & HW system. There are 2 HW cylinders located in the loft, below the cold water cistern.
Both CH & HW were working fine until I replaced 2 of the radiators, ever since ,the boiler fails to ignite (the pilot light remains off).
Before I made the replacements, I first turned both the HW & CH on the controller to OFF, closed the CH cistern tank supply valve, drained the system, replaced the rads, refilled the system (took a while due to the valve not opening up properly), bled the rads and finally turned the HW & CH ON at the controller.
First there was no response at all. then I found out that I may need to press the "red cross button" - some overheat system, after which the fan operated when the thermostat is turned up, but still no pilot light or ignition.
HELP
HELP
