I have a problem with a Potterton Profile 80e boiler. The boiler will go through sequence and ignite the main burner. The main boiler fires and stays alight for about 5 seconds and then goes out whilst the pilot remains lit. The main burner will then re-ignite and again, goes out. After three attempts, there are no more. The pilot remains alight, the fan is running, and the pump is running. To get the boiler to go through the same sequence, the mains supply needs to be turned off and on again. This is the same for both the heating and hot water although, the hot water responds almost immediately but the heating takes about 3 minutes before ignition.
The 3 way valve and pump are both working, and the engineer changed the boiler control pcb (The boiler was experiencing the same issue with the old pcb). One other thing I have noticed, is that the temperature control knob has a resistance when turned from 0 to max but then there is no resistance the other way until a few minutes later, almost as if a return spring is sticking and then freeing - I don't know if this is normal? The engineer is at a loss, and has suggested a new boiler. I'm hoping someone can help as it's been a couple of weeks now and it's a little chilly!
