Hi all.
I have a potterton promax sl boiler, which intermittently makes a really loud vibration/noise that seems to be a problem to diagnose as i cant always reproduce the noise. It won't happen from a cold start on the boiler....only after it's been running for an hour or so....and can go a week with no noise at all.
Does not happen on hot water, only happens on central heating. The noise is from the boiler itself and can be felt by pressing on the casing. I took the main case off while it was happening and the noise seemed to be from the bottom (fan area?).
The noise stops as soon as you turn the heating off, and you can turn the heating back on straight away and it clears.
Any ideas?
Any ideas?
