potterton puma 100-low system pressure!
18 Jan 2004
my boiler started leaking water from the cold water main inlet into the boiler(it's the water inlet shut off valve thats leaking) and the boiler light came on saying low system pressure.
i have checked all the electrics (as you do when your an electrician!)
went through the boiler manual but to no avail.
can anyone please point me in the right direction.
many thanks :cry:
assuming you have your leak fixed, you need to re pressureise the system, search these forums for filing loop and or low presure
no i did'nt fix the leaks but i will now.
thanks for the advice :D
The main CW boiler input is NOTHING to do with the system pressure!
Yes you have to get the system pressure right - around 0.7 - 1 bar when boiler is cold. If the pressure gauge indicates OK but the low P light is still on the pressure switch is blocked or bust. As a temporary measure only, you can unplug the switch from the board - lower left of pcb, just 2 pin connector, yellow wires.
i fixed the leaks and.......yes the low pressure indicator is still on.
looks like a new pressure switch.
many thanks :D
p.s i thought my plumbing was ok for an electrician! :p
so long as you did not try to thread the pipe like conduit and screw it in :LOL:
