My CH problem is: When CH is switched on the burner lights, the fan works, the pump works, then after about a minute the burner switches off and remains like that for about 3-5 minutes, then it repeats the cycle again. The HW is very hot when the tap is initially turned on, which is not normal. I have checked the pump and the voltages and all seem to be correct. I only get residual heat in the radiators. I have drained the boiler and refilled and released the pressure, which was very little.
Any thoughts please.
