Hope you can help?
I have hot water but the central heating only comes on occasionally. When the heating does come on it tends to turn itself off after an hour or so. Sometimes this seems to happen when the hot water is turned on for more than a few seconds. The boiler also randomly turns itself on and the water is very hot.
An engineer from British Gas changed the divertor but this has not solved the problem. There are no leaks or dripping taps and the pressure is fine.
BG have suggested that I may need to get the radiator system flushed out and or a new boiler (at great expense). I'm going to get a second opinion but in the meantime any thoughts would be much appreciated.
