hi guys, hope all is well and that you may be able to shed some light on this.
btw, i am a computer engineer, so can help with your pc problems if you like...however, i know nothing at all about boilers, so i hope you experts can help.
moved into new house about 3 months ago.
have a potterton puma 100e combi boiler, which is about 6 years old i think.
its been "system lockout"-ing out about once every 3 days or so, and a reset fixes the problem. this is ok, a bit annoying, but it doesnt matter.
however, a few days ago, it came up with "low system pressure" and refuses to do anything. i looked this up in the destructions and it says that the central heating system pressure is low if this comes on.
have tried turning power off and resetting, no joy
the pressure gauge is reporting 1.5 bar.
then bled all the radiators, there was some air but not tons (although, i dont really have a point of reference)
the system pressure dropped, so i brought it back up to the red needle on the pressure gauge (@ ~1.5 bar) by refilling the system with the "combi mate" valve that is below the boiler.
the gauge seems to be working, i.e. it drops when the rads are bled, and goes up when i put water back to the system.
however, the low system pressure light remains lit and it wont heat water or do the central heating.
have put the pressure up to 2 bar to see if this helps but it doesnt, and then taken it back down to 1.5 by bleeding the rads again.
none of my radiators appear to be leaking.
i have some of the old repair tickets for the boiler, and it says that 2 years ago the low pressure valve was replaced
anybody got any ideas please???
cheers
kev
cheers
kev
