Potterton Puma 100e tripping out house circuit breaker
28 Mar 2003
I've recently had a problem with water pressure dropping on this boiler and water flow from the hot tap seemed lower than usual. However this afternoon when I went to turn the heating on again the RCCB in the house circuit breaker had tripped out.
Every time I switch the boiler on at the wall socket the circuit trips. Even if I set the boiler switches to Standby and central heating to Off it still trips out.
I have tried fitting a spare modulation control board but same problem remains.
I have also disconnected both the fan and pump wiring connectors but it has made no difference.
What else could be causing this fault?
The gas valve or a micro switch?
Thanks for any help.
Thanks.
I'll have a look. If I leave it to dry out it may be ok?
:idea:
