We have a Potterton Puma 80 boiler, several years old. When we first moved in in November, the hot water was very temperamental - it ran hot for a bit, then cold, then hot again. We had it adjusted and all was fine for a while.
Now, only 3 months later, the problem is back again. The hot water is fine when the CH is on, but if it's not on it runs alternately hot and cold. Also, the boiler fires when turning the cold tap off. Weird.
Can anyone suggest what we can do to fix this? We want to try and do it ourselves cos plumbers are expensive!
Thanks,
Mary
Thanks,
Mary
